Toll costs details (c#) (xsers-1330)
Re: Toll costs details (c#) (xsers-1330)
and forwarded to data department...
one more question: can you tell us what your source is?
We gather the portuguese toll tarifs from various sources - maybe we miss some of them.
misunderstanding
I wanted to know from which webpage you retrieved the tarifs you compare with us afterwards
misunderstanding
Hi
example:
http://www.estradas.pt/calculador-porta ... custo&CL=3
Total (classe 4): 54,85€
On PTV (Vehicle Type = TRL): 17,28€
Origin: 38,7893518; -9,111231099
Destination: 41,14945984; -8,610309601
example:
Hi
Any news/ solution?
Any news/ solution?
Hello there,
here's the data experts feedback to your link:
It is unfortunately an online calculator, which cannot be really used as a reference. What we need is something like what I attached a file with date a all toll prices.
the weblink where we got the pdf is :https://www.brisaconcessao.pt/pt/client ... e-portagem
Do you have something compareable?
Hi
Your reference is correct.
Certainly must be doing something wrong, in assigning the type of car/truck.
as I'm getting class 1 tolls and should be class 4.
<q1:wrappedOptions>
<q1:VehicleOption parameter="TYPE" value="TRL" />
<q1:VehicleOption parameter="TOTAL_WEIGHT" value="15000" />
<q1:VehicleOption parameter="TRAILER_WEIGHT" value="20000" />
<q1:VehicleOption parameter="NUMBER_OF_AXLES" value="4" />
<q1:VehicleOption parameter="HEIGHT" value="400" />
<q1:VehicleOption parameter="LENGTH" value="2000" />
<q1:VehicleOption parameter="EMISSION_CLASS" value="EURO_4" />
</q1:wrappedOptions>
Hello Valter,
in the last request you provided you override some vehicle properties sauch as weight, dimensions, emission class and so on.
The server profile that is overridden is DEFAULT which is based on a car fast. I recommend to use one of our standard truck profiles and then override the properties you need to set through API.
If you choose "truckfast" you should get truck toll.
About the other topic (Braga/Gulmares) our DATA Department answered:
Best regards,Hi Bernd, this bug is fixed in xS2 (detail toll) and for xS1 a toll update should be planed.
