Feature Layer
dstest
Feature Layer
Post by dstest »
Hallo,
ich wir möchten FeatureLayers auf der Karte dynamisch zur Laufzeit ein und ausblenden. U.a. PTV_TruckAttributes,PTV_SpeedPatterns und PTV_TrafficIncidents (soll immer dann immer angezeigt werden unabhängig von routenplanung/xroute). Gibt es hierfür ein Beispiel in .NET wie dies einfach geschehen kann?
MfG
Frank
Re: Feature Layer
Hello Frank,
please check whether this post gives answers...
https://xserver.ptvgroup.com/forum/view ... layer#p900
The colleagues usually provide samples via GITHUB and if a sample is missing they can check whether they can add one.
Best regards from LINZ AIRPORT / Austria,
dstest
Re: Feature Layer
Post by dstest »
thank you for the answer.
i have seen the example. Thats exact what we need. But it doesn't work in my project with the .net mapcontrol we use.
Feature Layer Classes are the same. Call of the Procedure is the same. Only other thing is the kind of the Mapcontrol:
Private flPresenter As dsoft.logit.mgxsharp.FeatureLayer.FeatureLayerPresenter
Private Sub InitFeatureLayers()
flPresenter = New mgxsharp.FeatureLayer.FeatureLayerPresenter(pxFormsMap.WrappedMap)
flPresenter.ReferenceTime = Now
flPresenter.UseTrafficIncidents = True
flPresenter.UseRestrictionZones = False
flPresenter.UseTruckAttributes = False
flPresenter.UseSpeedPatterns = False
flPresenter.RefreshMap()
End Sub
Is there a problem with the mapcontrol we use? What do i have to change?
BR
Frank
Oliver Heilig
Re: Feature Layer
Post by Oliver Heilig »
Hello Frank,
i guess you are referring to thesample "FeatureLayers" here:
https://github.com/ptv-logistics/xserver.net-bin
We have changed the sample to fit to the latest version (1.6) of the control. This has some internal interface changes regarding xMapServe-access. To make this code work you can either revert to a pre-October version
https://github.com/ptv-logistics/xserve ... rovider.cs
or use the latest version 1.6.0 (inside the lib folder) in your project. I would recommend this anyways, because this will also be next supported version, and also abailable on GitHub
Oli
Oliver Heilig
PTV GROUP - Germany
dstest
Re: Feature Layer
Post by dstest »
Hallo Oliver,
leider konnte das Problem mit Komponentenupdate und Verwendung des neuen Feature-Layer Beispiels nicht behoben werden.
Die Fehlermeldung bleibt gleich. Ich habe ein Testprojekt hierzu hinzugefügt, damit Sie das Problem sehen könne.
Gruß
Frank
Maptest.zip
(1.23 MiB) Downloaded 739 times
Oliver Heilig
Re: Feature Layer
Hello Frank,
i've reviewed the sample and found the problem is that you must initialize the map with specific providers, and not just by setting xMapUrl.
I must admit this is a bit cumbersome, but was required because the default didn't support the ReferenceTime property, which is required for FeatureLayer. I've added this property to the basic xmap-1 provider. Now the special implementation isn't needed, and you can change ReferenceTime with the standard inplementation. Take a look at the new sample.
But this requires the latest revision of the control, which is available here: https://github.com/ptv-logistics/xserve ... master/Lib
Oli
Oliver Heilig
PTV GROUP - Germany
dstest
Re: Feature Layer
Post by dstest »
Hello Oliver,
thank you for the example. Now Feature Layers Work fine in our Aplication.
But i have found another issue. The Function of Map MouseToGeo now raises an error caused by Ptv.Components.Projections. Please find attached the Screenshot. I think i need the latest Projection Component too. Can you help me with that.
BR
Frank
Oliver Heilig
Re: Feature Layer
Hi Franke,
if you are using the transform functions with a specific coordinate system, you need to make sure you have the Ptv.Components.Projections.dll. But if you are just using standard WGS84 coordinates, you can also omit the parameter, because this is the standard format of the control.
var geo = map.MouseToGeo(e);
https://github.com/ptv-logistics/xserve ... ips.cs#L39
My recommendation is to always use WGS84 (x=lng,y=lat) coordinates in you project, so
[*] Omit the coordinate format for the map control, the default is WGS
[*] For xServer-1 requests use "OG_GEODECIMAL" to use WGS
[*] For xServer-2 requests, omit the, the default is WGS
Edit by JCL: fixed spelling error in xServer-1 coordinate format
Oliver Heilig
PTV GROUP - Germany
