New german toll 2019
fstrahberger
Post by fstrahberger »
in Germany there will be new toll rates beginning from 01.01.2019. I would like to calculate some routes with this new rates. Does xroute provide the new toll rates already?
If not, when will the new toll rates for 2019 be available?
Thanks in advance.
Florian
Re: New german toll 2019
Hello Florian,
if the latest version of our toll data is installed within your server you can calculate the toll based on the forecast data. This also contains the upcoming toll on FEDERAL ROADS. Please be aware that data that is labelled as FORECAST is subject to change!
Check this post which describes the content of the TollScenarios.ini:
https://xserver.ptvgroup.com/forum/view ... =859#p2519
Here are the GERMAN and ENGLISH properties of the current 4 scenarios in my local installation:
DESCRIPTION1DESCRIPTION2VALIDFROM / CREATEDATRELEVANCE / LASTMODIFICATION
Germany August 2017 / TollCollect GmbH, Federal Highway Toll Act (BFStrMG), BAStThis scenario contains the tariffs according to the tables 17.1 (highways) and 6.1 (federal trunk roads). This scenario replaces the previous 'Germany January 2017' scenario. Type of calculation: exact.20170806 / 20170401100% / 20170908
Deutschland August 2017 / TollCollect GmbH, Bundesfernstraßenmautgesetz (BFStrMG), BAStDieses Szenario enthält die Tarife gemäß den Tabellen 17.1 (Bundesautobahnen) und 6.1 (Bundesstraßen). Dieses Szenario ersetzt das bisherige Szenario 'Deutschland Januar 2017'. Berechnungsart: exakt.20170806 / 20170401100% / 20170908
Germany mid-2018 v10 / TollCollect GmbH, Federal Highway Toll Act (BFStrMG), BAStThis scenario contains the tariffs according to the tables 17.1 (highways) and 6.1 (federal trunk roads) on highways and on all federal trunk roads. This scenario replaces the previous 'Germany mid-2018 v9' scenario. Calculation type: forecast.20180701 / 201704010% / 20170908
Deutschland Mitte 2018 v10 / TollCollect GmbH, Bundesfernstraßenmautgesetz (BFStrMG), BAStDieses Szenario enthält die Tarife gemäß den Tabellen 17.1 (Bundesautobahnen) und 6.1 (Bundesstraßen) auf Bundesautobahnen und auf allen Bundesstraßen. Dieses Szenario ersetzt das bisherige Szenario 'Deutschland Mitte 2018 v9'. Berechnungsart: Prognose.20180701 / 201704010% / 20170908
Germany January 2018 / TollCollect GmbH, Federal Highway Toll Act (BFStrMG), BAStThis scenario contains the tariffs according to the tables 17.1 (highways) and 6.1 (federal trunk roads). New tariff for Warnowtunnel. This scenario replaces the previous 'Germany August 2017' scenario. Type of calculation: exact.20180101 / 20180102100% / 20180102
Deutschland Januar 2018 / TollCollect GmbH, Bundesfernstraßenmautgesetz (BFStrMG), BAStDieses Szenario enthält die Tarife gemäß den Tabellen 17.1 (Bundesautobahnen) und 6.1 (Bundesstraßen). Neuer Tarif für Warnowtunnel. Dieses Szenario ersetzt das bisherige Szenario 'Deutschland August 2017'. Berechnungsart: Exakt20180101 / 20180102100% / 20180102
Germany mid-2018 v11 / TollCollect GmbH, Federal Highway Toll Act (BFStrMG), BAStThis scenario contains the tariffs according to the tables 17.1 (highways) and 6.1 (federal trunk roads) on highways and on all federal trunk roads. New tariff for Warnowtunnel. This scenario replaces the previous 'Germany mid-2018 v10' scenario. Calculation type: forecast20180701 / 2018010295% / 20180102
Deutschland Mitte 2018 v11 / TollCollect GmbH, Bundesfernstraßenmautgesetz (BFStrMG), BAStDieses Szenario enthält die Tarife gemäß den Tabellen 17.1 (Bundesautobahnen) und 6.1 (Bundesstraßen) auf Bundesautobahnen und auf allen Bundesstraßen. Neuer Tarif für Warnowtunnel. Dieses Szenario ersetzt das bisherige Szenario 'Deutschland Mitte 2018 v10'. Berechnungsart: Prognose20180701 / 2018010295% / 20180102
fstrahberger
many thanks for your Information. I have already tried to calculate routes with toll date 01.07.2018. Then the federal roads are included in the toll calculation.
But my boss wants to know how much the toll will be, beginning from 2019 as the toll rates will be raised: http://www.spiegel.de/auto/aktuell/lkw- ... 07819.html
Is there any chance we may calculate a route with the raised toll rates from 2019.
Thanks in advance.
Florian
Hello Florian,
this is a strategic question and I have to forward it to our product management.
fstrahberger
many thanks for this Information.
Florian
Hello Florian,
here's some short statement from product management (translated by myself):
The new tarrifs which are relevant from 1.1.2019 aren't scheduled or finalised so far. Probably the work on this topic will start in november which will ensure that the updated tarrifs will be ready for use before they apply. Another prognosis isn't scheduled. Due to high workload in the data team we can't provide the update earlier,
Max Beermann
Post by Max Beermann »
Good morning Bernd,
regarding to the ptv-homepage, the forecast-data of the german toll (20190101) is available yet.
I tried to to calculate the toll-costs for some routes by using the following parameters, but it does not work.
(It worked for the toll-change regarding "2018-07-01")
xroute
calculateAdvancedTour
<CountryInfoOptions_6 tollDate = "2019-07-05" detailedTollCosts="false" allEuro="false" calculatePartTollCosts="false" />
Is my code wrong or do I use an old map?
PTV Europe City Premium Map 2018.2
Maybe you see my mistake and can give me a hint.
Thank you very much in advance
Max Beermann
Max Beermann
Development Manager
WHEELS Logistics
Hello Max,
I think your request is ok but the server you use needs to apply the latest toll updates.
This means you need to
  • PTV-xServer INTERNET : cloud services are already providing the latest updates
  • PTV xServer OnPremise: install Content Update Service
The Content Update Service will connect to the PTV servers periodically and download updates of the Toll Data (e.g. check for updates once per week).
Internal Testclient: computes toll for three Tolldates.<br />The track is the same for all three toll dates, but:<br />from 1st to 2nd scenario: toll distance increases as FederalRoads produce contribution now (started 1.7.2018).<br />From 2nd to 3rd scenario: same toll distance but tarifs increased.
Best regards from Germany,
Max Beermann
Good morning Bernd,
thank you very much!
PS: It is awesome (and fun) to work with xServer.
Max
Max Beermann
Development Manager
WHEELS Logistics
