we have the requirement to plan tours for several days which might include multiple visits of one customer. Lets say we plan a tour from monday to friday and have one customer that has to be visited every two days. That means that we have to visit that customer multiple times in that tour. When we add multiple TransportDepots for this customer to the tour, the optimization places these visits next to each other in one day to save driving times. This makes total sense when trying to minimize the driving distance but does not satisfy our needs. Is there a way to define a minimal time span between multiple visits to the same address/Point/Depot in one tour?
Christopher
Multiple visits to the same customer in one tour
ChristopherM
Re: Multiple visits to the same customer in one tour
it can be done by first dividing the order over the days with xCluster, then to plan the days with xTour. Have a look at the xCluster use case description for planning a week:
https://xserver.ptvgroup.com/fileadmin/ ... n_Week.htm
ChristopherM
Thanks for your reply, Joost.
Just to make sure that I understood you correctly: I have to plan each day separately by calling the xTour server once for each day after I distributed the visits over the days using xCluster? Or is there a way to do this with one request?
Christopher
Christopher
You can do it with one request. You just have to set the correct intervals for the opening times of the order.
let's start with the story:
About Joosts second comment with the operating intervals:
If you set the two orders to
order 1Alpha's opening times = MON+TUE
order 1Beta's opening times = THU+FRI a solution such as o1a is visited on MONDAY and O1b is visited on FRIDAY is valid. Imagine you want to enforce "the defect is 2 days" you might use xCluster patterns such as
MON+WED
TUE+THU
WED+FRI
to ensure the "period" between the visits is defined. This won#t be possible with the single call (due to the missing dependency between orders in xTour).
PS: for a proper check I recommend to get in touch 1:1 with your local consultant
- you have several customers to visit in the next week
- some of these customers require more than one visit
- those visits should not occur on the same days but e.g. with at least 2 days "break" in between
- Use xCluster.planWeek or planMultiWeeks and assign rthe proper patterns for the customer, e.g.
MON+THU or MON+FRI or TUE+FRI. This will assign such a multi visit customer to one of those patterns. - Then you can optimize day per day using xTour
MON+WED
TUE+THU
WED+FRI
