Looking for solution to display active region in Map center
webdirekt
Post by webdirekt »
- We have the list of Points (i.e. X and Y coordinates) and Geometry data with respect to list of zip codes.
- Based on result of Geometry data; we have added BaseLayer in the map using the tile renderer which is implemented from ITiledProvider interface (Ptv.XServer.Controls.Map.Layers.Tiled).
- We have set the map control envelope using the list of Points (i.e. X and Y coordinates).
wpfMap.SetEnvelope(new MapRectangle(pointList), "OG_GEODECIMAL");
-- wpfMap: ptv wpf map control.
-- pointList: list of Points (i.e. X and Y coordinates).
-- "OG_GEODECIMAL": Point format
Issue:
Active region is displayed in the center of the map as expected but some part of the region is still out side the map.
Find "ActiveRegionActualResult.png" which shows the current display of Map
Find "ActiveRegionExcpectedResult.png" which we want to display the Map in our App
Solutions tried:
We tried to decrease the zoom level of map programmatically as mentioned below, but its not working.
Option 1:
ptvMap.Zoom = ptvMap.Zoom - 1;
Option 2:
ptvMap.ZoomLevel = ptvMap.ZoomLevel - 1;
Oliver Heilig
Re: Looking for solution to display active region in Map cen
Post by Oliver Heilig »
are you sure you're getting you points right? It works for me as excpected.
How i verified this:
[*] Downloaded the project https://github.com/ptv-logistics/SharpMap.Widgets
[*] Set SharpMap.Win as startup project
[*] at Form1::SelectedRegions_CollectionChanged change like below
Note: The SetEnvelope method set the map section to fit the envelope exactly longitudal or latitulal, depending on the ration of the window/envelope. You can use the MapRect.Inflate() method to increase the size to get a buffer.
Oli
        private void SelectedRegions_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
            if(this.selectedRegions.Count == 0)
                propertyGrid1.SelectedObject = null;
                return;
            var selectedItem = selectedRegions[0];
            // test: set the map envelope to fit the selected item;
            // ... using Ptv.XServer.Controls.Map;
            // ... using GeoAPI.Geometries;
            // set the maprectangle from sharpmap geomatry
            var envelope = selectedItem.Geometry.EnvelopeInternal;
            var rect = new MapRectangle(
                new System.Windows.Point(envelope.Right(), envelope.Top()),
                new System.Windows.Point(envelope.Left(), envelope.Bottom()));
            // inflate by 20%
            rect.Inflate(1.2);
            this.formsMap1.SetEnvelope(rect);
            // dump all attributes
Oliver Heilig
PTV GROUP - Germany
webdirekt
Post by webdirekt »
Thank you very much. It works perfectly for us and solved the issue. :)
