Latest version of Leaflet supported by PTV components
biro.daniel
Post by biro.daniel »
Hello guys,
could you share with us which is the latest version of Leaflet supported by PTV components?
Thanks in advance,
Daniel
hacon_mgab
Re: Latest version of Leaflet supported by PTV components
Post by hacon_mgab »
Hi everyone,
I was wondering the same. We would like to use PTV Feature Layer with the Leaflet PtvLayer class in order to show Traffic incidents etc. It turns out that it is not working with Leaflet 1.0.1 which we're currently using. With Leaflet 0.7.x I was able to make it work. Are there plans to make it compatible with Leaflet 1.0.1 for example? We rely on that version so we have no chance to go back to 0.7.x.
Any help is appreciated.
Thanks
Michael
Please have a look at http://xserver.ptvgroup.com/de/cookbook ... on-github/ . The first project contains the scripts to connect xMap to leaflet 1.x
Oliver Heilig
Post by Oliver Heilig »
We don't support dedicated Leaflet-Clients for Leaflet > 0.7
If you are using Leaflet with xMap-1, we recommend using the WMS/Tile-Servlet, see
https://github.com/ptv-logistics/xserve ... ate/xmap-1
If you need extended Layers, take a look at
https://github.com/ptv-logistics/Leaflet.PtvLayer
A sample for the use of Feature-Layers:
https://github.com/ptv-logistics/fl-labs
If need more samples, especially for xMap-2, take a look at
https://ptv-logistics.github.io/xserverjs/
For more samples
Oli
Oliver Heilig
PTV GROUP - Germany
hacon_mgab
Thank you all for your replies, we'll go for WMS/Tile-Servlet Solution then.
