Detour points
Re: Detour points
The computatio of a 6000x6000 matrix can be done within less than 1 minute (my local example took 45 secs), but my stomach tells me we are on a wrong path.
Let's get several steps back:
Imagine you could wish a blackbox function where you provide a given input and describe the required output.
From a functional usecase point of view (forget each method of xServers for a moment):
how would the signature of the function look like?
I think I might provide a better solution for the original task then...
coverage of 7000 (!) locations around Paris. Computation time: 60 seconds.
Re: Detour points
You do not need to calculate a full 6000 by 6000 dima. You only need to calculate 2 by 6000. I suggest you do this with 2 calculateMatricInfo calls from xRoute. If you use high performance routing this should be done quick. I don't have exact numbers unfortunately but probably around a few seconds per call.
Be aware though: for such big calls it can be that the framework will hit it's maximum memory usage. I'm not expecting it with your numbers but I would recommend for you to stress test your solution before deploying it into a production environment. If it does you can always increase the maximum memory if needed. See:
http://xserver.ptvgroup.com/fileadmin/f ... n%7C_____2
clegroux
Re: Detour points
Post by clegroux »
Okay!
I would like a function which takes three arguments :
  • - the startpoint location (A)
    - the endpoint location (B)
    - the time I have to go from startpoint to endpoint (T)
As a result, I would like to get a polygon which ensures that every point N in it verifies (A:N) + (N:B) < T where (X:Y) represents the time to go from X to Y
Re: Detour points
That's the point.
The polygon itself is useless.
What do you need it for in a later step?
You want to determine as quick as possible for a given customer whether you can add him to such a tour?
clegroux
Re: Detour points
Post by clegroux »
Yes and no... ;-)
In fact I have a lot of vehicles tours on several days (from a date D to D+14). Some are full, some not. For a new given customer :
  • 1- I want to know quickly what vehicles can visit this customer
    2- If no vehicle can visit this customer, I want to know at what date I should open a new tour to visit this customer. And here is the point, I don't want to open a new tour on day X if this new tour's area intersects too much tours areas (on day X). For a given day, I finally want to cover my map as much as possible.
Re: Detour points
So all the existing tours start at A and end at B?
But I assume they server other locations as well.
How about using findToursForOrder which will give you a quick feedback about
  • Which one of the tours can be extended with less than NN kilometer detour?
  • What is the impact on these tours?
If no tour is returned you could decide to create a new tour.
PS: I recommend to get in touch 1:1 with your technical counterpart at PTV.
Who's that? Maybe I can moderate?
Re: Detour points
Another approach mentioned by DEV (Thanks, Ralf!) is as follows:
  • Determine a set of potential C's
  • Use searchForNearest(Sink=A, Candidates=C's, direction = forward, horizon=2h) : returns Candidates A:C's
  • Use searchForNearest(Sink=B, Candidates=C's, direction = backward, horizon=2h) : returns Candidates C's:B
  • Filter those candidates C's where (A:C) + (C:B) > 2 hours...
But: be aware that the performance of searchForNearest scales superlinear with the horizon!
clegroux
Re: Detour points
Post by clegroux »
Sorry for this late response...
Here is an example :)
I have two tours on day D and on day D+1. I have a new customer to visit and I may visit it on day D or on day D+1. This customer can't be visited by vehicle 1 or vehicle 2 so I have to open a new tour.
Is it more efficient to open a new tour on day D or on day D+1?
Here this answer is day D+1 because the new tour will cover 80% of the area defined by tour 1 and tour 2 on day D. On day D+1, it will only cover 20% of this area.
The approach mentioned by Ralf is a good idea but it requires to determine the set of potential customers and the only way I see to do that is by slicing my map...
Charlie
Re: Detour points
Ah, I see. But that's a different target then.
If you want to optimize reachability and coverage you might take a look at this feature of xCluster:
http://xserver.ptvgroup.com/forum/viewt ... f=10&t=482
Not exactly what you are looking for within this thread but related to "how to cover a broad area?".
