is it possible to change the tour creation handling of "planBasicTours", to start a new tour after the the truck is completely unloaded.
Frank Mertens
xTour: split tour after complete unloading.
Re: xTour: split tour after complete unloading.
Hello Frank,
I'm not sure what the intention behind this special requirement is. I assume, you are dealing with pure AB-orders.
There's no direct approach how to achieve what you describe but maybe you simply want to avoid a specific structure of results? If I'm correct: what is this "no go"-structure?
this behavior is requested by our planning department to match the current in-house approach. But at the moment it's not clear, if this is a must-have feature. If it remains necessary, I have to split the result by myself.
Frank
Frank
Hello Frank,
I still didn't get the expectation behind this question?
Can you describe the usecase a bit more in detail?
