Problem with Housenumber-Range in Street field
Howard
Post by Howard »
we just encountered an issue with an address and I was trying out different settings in the xLocateServer but I wasn't able to get better results.
country="D"
postCode="12105 "
city="Berlin"
street="Ringstr. 103/106"
This will return hits with completely different postcodes, but with Streets like "Straße 106" and "Straße 103".
If I remove the "/" from the street and replace it with a space, it works fine. "-" also does not work.
It's unfortunate that I cannot use put the house number in the appropriate field, since that would fix everything. :?
Any suggestings?
Sven Howard
Re: Problem with Housenumber-Range in Street field
Hello Sven,
how about this approach? I changed some values in the native profile:
<HNr.RangeSeparators Value="" Type="string"/>
<Intersections.Enable Value="0" Type="bool"/>
<Intersections.Separators Value="\¤ at ¤ @ ¤ ecke ¤" Type="string"/>
Result after the proposal has been applied
Looks good...
Howard
Post by Howard »
That does the trick!
Thanks you very much. :)
Sven Howard
Sven Howard
Wessendorf Software & Consulting GmbH
http://www.wsc.biz
