RouteCalculationCriteria: difference between ABSTRACT_COSTS and MONETARY COSTS
Posted: Thu Mar 07, 2024 8:30 am
many customers are comparing the well known MAP&GUIDE Internet routes (based on HERE and xServer1) with their results gathered trough PTV xServer2 and PTV Developer (check this concept, too):
Let me collect some info about this MONETARY approach we invented in PTV xServer2 in 2020...Hi, whats or why the difference between Map&Guide and monetary settings? What it offeres different route in our planner? Can you pls. check it a/o explain?
- Routing in general:
- In the context of a routing each road segment has a price which is usually determined based on a combination of segment and vehicle properties. That's why we offer more than 100 parameters to control the routing calculation.
- The "best route from A to B" is a connected set (path) of segments that links the two waypoints and that minimizes the "aggregated costs" of the involved segments.
- ABSTRACT : In PTV Map&Guide Internet and PTV xServer1 the only routing mode was the abstract one. All segment prices are based on a virtual cost metric that applies several percentage bonus/malus values to add/reduce the virtual costs of segments as some kind of weak or strong preferences / avoidances. This approach has several disadvantages:
- It is complicated. We often had discussions with users about the proper malus values. Or they told us "the result was fine with a malus of xx% - but can you explain why?" - and we couldn't.
- It does not consider the segment's real toll prices at calculation time. With this abstract approach the toll is determined in a post processing step.
- MONETARY : Now with the new monetary approach the segment's price is now derived from real fiscal values and these costs are used during the calculation of the optimal (cheapest) path:
- Price per working hour
- Price per distance
- Toll price
- Price per "fuel/energy" consumption
- Also relevant to consider
- As we do not know the prices of ferries you would have to add ferries manually into the waypoints list
- MONETARY does not support ALTERNATIVE ROUTES.
You may send different tarrif settings instead. - It might be necessary to combine the monetary approach with geographic restrictions, e.g. if you want to avoid a delay at the Swiss customs which sometimes causes detours around Switzerland (but within the EU) to be cheaper.
